12 years agoHelp with Nios II linux from rocketboards.org
Hello! According to http://www.alteraforum.com/forum/showthread.php?t=42090 there is a new linux guide. So I have some question. Is uClinux for Nios II still being developed? If yes, what have b...
12 years agoHi Vdvoznyuk,
First, the uClinux for nios2 will not be developed unless some one else pick up the work. The Blackfin dist migrated to buildroot last year. You may keep using the existing Blackfin uClinux-dist. Just that there won't be update of it. Second, the booting issue of rocketboards. Please check if you use irq0 on your design, change it to nonzero one. Cheers, Hippo
