12 years agoHelp with Nios II eclipse, can't create project
Hi! I'm having a problem with creating a project in Nioss II eclipse. When I go to file/new--> Nios II application and BSP template, I have to find the SOPC information file. I have no problem ...
12 years agoYou need a board to "run as hardware" : an Altera Dev kit board or your custom board.
You need to match your software with your hardware. More precisely, you need to match your BSP (software) with your QSYS/SOPC which should be in your FPGA on your board. A fail download is often caused by a watchdog, a reset, Mismatching Qsys/SOPC (see "sysid").
