19 years agoHelp with IP - sending packets PC to FPGA
I am working on a remote-operated vehicle project that requires sending packets back and forth between a PC and a Cyclone II FPGA. Thus far, I've tried example projects DE2_NET (on Altera's ...
19 years agoHippo,
You suggested using the uCLinux for Ethernet development. Can you tell me what your average throughputs are for UPD? Also, what is the minimum code size for uCLinix running Ethernet. All I need is UDP communication with static IPs. I do not need telnet, ftp, dhcp, etc. Ideally, I would like to have this operate within the FPGA out of mRAM. Does anyone have experience with this? Thanks!
