11 years agoHelp with FPGA-HPS Interrupt on Baremetal Application
I have been working on baremetal application, generating interrupts in the FPGA to be handled by the HPS using the HWLib provided. The problem is, I have initialized everything as per the examples pr...
11 years agoTry to check what is the interrupt number you are trying to catch.
To make story short, this is the code: alt_int_dist_target_set(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3, 0x1); alt_int_dist_trigger_set(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3, ALT_INT_TRIGGER_EDGE); alt_int_dist_priority_set(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3, 1); alt_int_dist_enable(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3); alt_int_isr_register(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3, my_isr_callback, NULL);
