21 years agoHelp using QuartusII
Hi all!!! I've a question that may be simple for someone of you... Let's suppose that in Quartus II I have to merge 2 wire in a single bus: in1------>|
21 years agoHi larsen,
I can remember that I had similar problems with assignments to pin-locations. I think I could solve it using outSignal[2] instead of outSignal2 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif . Maybe this also helps in your case. BTW: I only use lower-case symbol-names, I think I read somewhere in the "Known Issues" section, that using upper-case in symbol-names can lead the some problems http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif . Regards Thomas www.entner-electronics.com (http://www.entner-electronics.com)
