21 years agoHelp! trace back utility for NiOS
Hi: Can someone please let me know whether there is a traceback utility in NiOS? I want to print the function call trace in run-time, just like gdb but without using NiOS console. I want this...
21 years agoThanks for your reply, can you please let me know if there is an example code around? And what is the compiler option
to enable frame pointer, i'm not optimising the code, will not framepointer be already there? Thanks and Regards, Balaji
