21 years ago
Help regarding NiosII IDE
I am having problem inporting existing project into NiosII IDE.
I followed following procedure..
In Nios II IDE : File > inport > Existing altera nios II project into workspace > then browsed to
my already existing project (hello_led_0).
The pop-up window indicates (error) project already exists and finish button is not highlighted.
What I am trying here is to import already existing project into Nios II IDE and edit/build/run it.
( the only way i thought might be to create another new C++ project(hello_led_1) and proceed
in Nios II IDE workspace).
I don't know if I an missing anything.
I appreciate your suggestions.
    ### "Eclipse works different than other tools,
    why make something easy, if you can make it very complicated ?"# ##
    you cannot have two projects with the same name in navigator, even they are
    in different directories.
    you have two possibilities.
    1. in navigator view right click on already existing project and delete it, it normally
    shows a message box where "do not delete contents" is selected, which means that it only
    removes the project from the navigator view and not from the disk. After that you can import
    the project from another location.
    2. I sometimes copy exitsting projects from one location to another, then I open the
    file ".project" and change there the name of the project to a new name.
