20 years agohelp, Programming flash error!
in my custom board, i can read the flash and can not write to it ,following is the information when i use the flash Programmer: # ! /bin/sh# # This file was automatically generated by the Nios ...
19 years ago --- Quote Start --- originally posted by cosmosd@Oct 15 2006, 05:22 AM in my custom board, i can read the flash and can not write to it ,following is the information when i use the flash programmer:
# ! /bin/sh# # this file was automatically generated by the nios ii ide flash programmer.# # it will be overwritten when the flash programmer options change.#
cd d:/altera/kits/hello_world_pll/debug
# creating .flash file for the fpga configuration
$sopc_kit_nios2/bin/sof2flash --flash=u2 --offset=0x0 --input=d:/altera/kits/cy1
2pll/cy12pll.sof --output=cy12pll.flash
the flash is am29lv128ml-123rei, and i use the preset flash parameter in sopc builder,the osc is 50mhz,wiht q5.0, i have also examed the board several times and the connection is ok ! please help me,thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18699)
--- quote end ---
--- Quote End --- Let me say go different page at the first try. I did have a board with bad flash page on 0.
