19 years agoHelp! Problem in linking!
I met the problem whem linking: Unable to reach (at 0x0009bf4c) from the global pointer (at 0x000861e0) because the offset (89452) is out of the allowed range, -32678 to 32767. The code was ...
19 years agoBut I can run seccussfly the same code in ARM7 platform. So, I think the code is all right.
Now I want to port the code into Nios2. The problem is what is the right -G compiler option。
