19 years agoHelp! Problem in linking!
I met the problem whem linking: Unable to reach (at 0x0009bf4c) from the global pointer (at 0x000861e0) because the offset (89452) is out of the allowed range, -32678 to 32767. The code was ...
19 years agoyou should double check your code, something should be wrong with your source.
you can try get rid of the variable which lead to fail.
