19 years agoHelp! Problem in linking!
I met the problem whem linking: Unable to reach (at 0x0009bf4c) from the global pointer (at 0x000861e0) because the offset (89452) is out of the allowed range, -32678 to 32767. The code was ...
19 years agoYes, I've tried from -G0 to -G4. But it didn't work!
The Altera's document didn't say clearly. --- Quote Start --- originally posted by mrwgm@Oct 26 2006, 04:24 AM hi dugufei,
did you try -g0 ?
i had this problem with redboot... fixed with this option. found somewhere here in this forum. maybe it works for you, too.
regards, martin
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18925)
--- quote end ---
--- Quote End ---
