19 years agoHelp! Problem in linking!
I met the problem whem linking: Unable to reach (at 0x0009bf4c) from the global pointer (at 0x000861e0) because the offset (89452) is out of the allowed range, -32678 to 32767. The code was ...
19 years agohi Dugufei,
did you try -G0 ? i had this problem with redboot... fixed with this option. found somewhere here in this forum. maybe it works for you, too. regards, martin
