14 years agohelp: ping is ok, but telnetd and ftpd doesn't work
hi, based on the nios2-linux-20100621.tar, I refer to the step by step in www,alterawiki,com / wiki /UClinuxDist then I get a zImage booting successfully on the altera's 3c120 de...
14 years agoI have run <./checout> under dir nios2-linux, I think this will git to update the system.
the following script is in the checkout file: for i in binutils gcc3 linux-2.6 toolchain-build toolchain-mmu uClibc elf2flt insight u-boot uClinux-dist do cd $i git checkout -f cd .. done if I download the zImage of www, alterawiki.com/wiki/ Try_out_without_compilation , telnetd will work. there is "altera tse mii bus: mdio bus registered" message when booting. but when I download the zImage generated by myself, there is no "altera tse mii bus: mdio bus registered" message when booting. So I'm looking to the driver code. any help is appreciated!
