13 years agohelp on rs232 communication niosII
How do I get to communicate with the Nios II via serial pc? Basically I would like nios II sends a string to the serial port. I use The Nios® II Software Build Tools (SBT) for eclipse. ...
13 years agoI solved it using the code posted by Kaushal. I was wrong path of my RS232 file from system .h ...
I opened the file system.h, and I put the right path. Note: if you use a serial sniffer like Hyperterminal you check that you have it set up correctly.. Sorry for my english but I am Italian if there are any problems please do not hesitate to ask. :D
