20 years agohelp me,save my memory
hi! my application use more memory in the nios than arm platform I use the objdump print as follow: [root@localhost pppd]# nios2-elf-objdump --header pppd_dump.elf pppd_dump.elf: file...
20 years agoHi,hippo!
I build the boa in the arm platform,the message boa process is as follow:# cat status Name: boa State: S (sleeping) Tgid: 60 Pid: 60 PPid: 56 TracerPid: 0 Uid: 0 0 0 0 Gid: 0 0 0 0 FDSize: 32 Groups: Mem: 157792 bytes Slack: 2876 bytes Shared: 0 bytes SigPnd: 0000000000000000 SigBlk: 0000000000000000 SigIgn: 0000000000001a00 SigCgt: 0000000000016443 CapInh: 0000000000000000 CapPrm: 00000000fffffeff CapEff: 00000000fffffeff can you show the boa process status in your nios platform?
