20 years agohelp me,save my memory
hi! my application use more memory in the nios than arm platform I use the objdump print as follow: [root@localhost pppd]# nios2-elf-objdump --header pppd_dump.elf pppd_dump.elf: file...
20 years agoHi Hippo,
We do use the nios2 cross compiler tools according to your buildroot POST. But the size of the applications(pppd) code and its size in SDRAM all more bigger than arm+ linux2.4.x. Could your give your applications(pppd) parameters? Such as using cat pid/status and objdump .
