21 years agoHelp me to test my nios2.
Hello, I have created a min nios2 system(Nios2, OnChipRam, Uart) and want to test if it can run Hello_world.c in my Dev.Board. So I do the following: (My Dev.Board is Micortronix Cyclone Dev.Bo...
21 years agoThank you.
I do as you say and the project can be built. I only change the properties of the project, not enlarge my OnChipRam size. But when I am running the project, another problem occur. Please see the description below. (1) I choose Run>Run... in the IDE window. (2) Double click on Nios II Hardware in Configurations. A new item display with "hello_world_0 Nios II HW configuration" automatically. (3) I make others by system default and click "Run". (4) The console appears and display with two command line. nios2-terminal: connected to hardware target using UART on /dev/com1 at 115200 baud nios2-terminal: starting in terminal mode only (Control-C exits) (5) And console stays here, no other information is displayed and "Hello from Nios II!" was also not displayed. What is the problem? (I use the Microtronix Cyclone Dev.Board) Please help me. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
