13 years agoHelp me in audio code, please! (about I2C SCL BASE )
Hi all!! I applying audio code demo of altera. But when I build project, it had 2 error : 'I2C_SCL_BASE' undeclared (first use in this function) AUDIO.c /audio_de2_115_MTL line 357 ...
13 years ago --- Quote Start --- Apparently the code you are compiling is looking for two peripherals in your system, one called i2c_scl and another one i2c_sda, but they aren't present. You should add them to your SOPC Builder or QSys project. From the names I'm guessing they are 1 bit bidirectional PIOs. --- Quote End --- Thanks for your advice,Daixiwen! I did review my SOPC, it have enough component for audio. And in define of function I2C_write(); the sample code was define I2C_SCL_BASE is clk_base and I2C_SDA_BASE is data_base. But I don't understand what are the address of clk base and data base? I found it in the internet but it haven't had the info. I need!! (T_T")! hix hix, Who have another idea please help me (^_^")!!!???
