21 years agohelp me about cfi
i am a beginner of this field. so many problems block me. i have a ep1s80 dev board and a ep1s25 dev board.but i can't program flash on these board. the preset of the cfi does't support...
21 years agoffone,
The nios 1.01 release does contain a change in this function which was made to make it work with 16 bit flashes in 8 bit mode. The error you're getting is basically that the code cannot get a valid CFI response from the flash. I would recommend you try 1.01 .
