16 years agohelp linux on neek.
Hi
I always want to finish the tutoriel ExtremGuide To kill neek I see there is something new on the linux-2.6.git in arch/nios2 : a board folder for neek. Furthermore, the page http://www.nioswiki.com/linux/creating_a_nios_ii_design_with_an_mmu has been updated. So i suppose that now the uClinux-dist can directly be compiled for neek. So I tried : First update my linux-2.6.git and uClinux-dist.git by doing git clone -n git://sopc.et.ntust.edu.tw/git/linux-2.6.git cd linux-2.6 git checkout -b my_nios2mmu origin/nios2mmu and the same for uClinux-dist Then after setting up the correct PATH env variable to the toolchain : make menuconfig Select Altera and nios2 Then Kernel config Then Nios2 Configuration Then Nios2 Board Configuration Then select Neek and whatever i choose for FPGA configuration, when i make it crashs Is is already stable this new method ? Then after the Extrem Guide to kill neek page should be updated for the 6th step in order to set up the MTD and the jffs24 Replies
Updated to v2.6.34. Please try out the prebuild images first.
Then use the attached config files to build uClinux-dist. What do you mean crach? - Hippo - Altera_Forum
I didn't understand your reply.
I just have understand your proposition to try with the prebuild image that are below the Extrem Guide on the wiki. - Altera_Forum
Yes. Please try to program the flash using attached images before doing any compilation.
Hi Hippo,
I am finally be able to use Linux in my NEEK with MMU enabled. However, that uClinux is only interactive in my nios2-terminal for few minutes in which i can access its filesystems, after that it just hang. what seems to be the problem?
