13 years agoHelp in CRC custom instructions please.
Hello, I am a new bie in the custom instruction development for Altera and was looking into the way the CRC method is implemented as per the link altera.com/support/examples/nios2/exm-custom-...
13 years agoHello Daixiwen,
Thank you for the reply. And I think I have seen that checksum hardware accelerator example in the SOPC user manual. The issue with that is, that is too much a high level for a beginner to start with. It does not explain how to create a sw.tcl file and the *.c and *.h driver files (I think all those files are to be hand-coded). Also the build process explains a NIOS II SBT build, and which is specific for a Cyclone IV device. I use the DE1 board here, which has the Cyclone II device in it. So is there any simple example for the SOPC builder component which I can refer to? That would be a huge help. Thank You, Akhil
