20 years agoHelp for "Link address offset for booting"
I follow the hippo instruction to make the zImage. I do it. But when I donwload by "nios2-donwload -g zImage" and after call "nios2-terminal" nothing happen! I insert console on jtag in linux kern...
20 years ago --- Quote Start --- originally posted by marco.faletra@Jul 4 2006, 05:53 AM if i try http://nioswiki.jot.com/wikihome/operating...zimage_std_1c12 (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux/zimage_std_1c12) everything is all right. so the problem is in the kernel linux and not in hardware, but where?
how can i debug if i don't see nothing? the problem i think is in jtag-console but i haven't found nothing!
thanks for your help.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16643)
--- quote end ---
--- Quote End --- Hi Marco, I am not confirm but you can try this .... If you have enabled JTAG uart + "prints over JTAG uart (next option)." then after nios2-download -g zImage is over, run nios terminal -> nios2-run -t or nios2-terminal wait for a while (5-10 sec) and press enter ...... [I might sound stupid but just try once http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif ] If you still don't get any prints than disable jtag uart and use serial uart for prints on hyper terminal.. Get confirm that you hardware design have support for both. thanks, ankur
