21 years agohelp for flash programming error!
I'm using QuartusII4.2+sp1,NiosII1.1,ByteBlasterII cable, and an EP1C12Q240 on my custom board. I built a flash programmer design as the "NiosII Flash Programmer user guide" instructs...
21 years agoHi Scott, thanks to you
It's my own project named NIOSII_DEV, and the custom board named NIOSII_DEV_BOARD. I can programme a data file to epcs4 but can not programme it to flash(SST39VF040). <div class='quotetop'>QUOTE </div> --- Quote Start --- # Programming flash with the project $QUARTUS_ROOTDIR/bin/jre/bin/java.exe -jar $SOPC_KIT_NIOS2/bin/nios2-flash-programmer.jar --input=SST39VF040_70_4I_NH.flash --sof=__NO_SOF_PLEASE__ --base=0x00080000 Jun 24, 2005 3:53:30 PM - (??) nios2-flash-programmer: SOF-download skipped. Jun 24, 2005 3:53:33 PM - (??) nios2-flash-programmer: Error opening target hardware Jun 24, 2005 3:53:33 PM - (??) nios2-flash-programmer: Unable to open flash-device after successfully communicating with target.[/b] --- Quote End --- --armen
