13 years agoHelp FIFO, external bus connection SOPC
I am developing a project in which I need to connect a 16-bit bus to a NIOS processor, using a FIFO, I used "on chip FIFO", but do not know how to configure it to be able to have the input of FIFO in the schematic generated by SOPC.
:( Would be very grateful if you could give me an example of the connection of the FIFO.1 Reply
You need to export the slave interface of the fifo output port.
This can be easily done using the external master component that I posted in this thread: http://www.alteraforum.com/forum/showthread.php?t=37585
