16 years agoHelp ERROR: SOPC_KIT_NIOS2 - Undefined variable
Hi i am a beginner in using nios.I tried to build hello world from nios ide and its giving me the following error D:/altera/91sp2/quartus/NIOS_DE2/software/Testing_bsp/../../TOP_LV.jdi ERROR:...
16 years agoMarmota77,
you can install nios ii v10.0 in windows 7, it's supported. if you still encounter same problem, try to build the project in command shell. invoke the command shell from nios ii workspace. right-click project --> nios ii --> nios ii command shell --> and type 'make' to build the project. please check the environment variables. thanks, caridee
