15 years ago
help:.elf cannot download to fpga
hi:
when I download .elf to FPGA ,but faileded ,
!SESSION 2011-06-13 11:27:44.687 -----------------------------------------------
!!ENTRY com.altera.sbtgui.launch 2 0 2011-06-13 12:04:09.546
!MESSAGE The expected CPU name does not match the selected target CPU name.
!MESSAGE The expected Stdout device name does not match the selected target byte stream device name.
!ENTRY com.altera.sbtgui.launch 1 0 2011-06-13 12:04:12.000
!MESSAGE Executing: [C:\WINDOWS\system32\cmd.exe, /C, C:/altera/10.1/quartus\bin\cygwin\bin\bash.exe, -c, nios2-download '--cable=USB-Blaster on localhost [USB-0]' --device=1 --instance=0 --sidp=0x25018 --id=0x0 --timestamp=1307935183 /cygdrive/d/10.1/apical_top_sq/apical_top_demo_isp_youjing/pri_apical/software/fsysid/fsysid.elf]
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:04:20.250
!MESSAGE Failed Executing: [nios2-download, '--cable=USB-Blaster on localhost [USB-0]', --device=1, --instance=0, --sidp=0x25018, --id=0x0, --timestamp=1307935183, /cygdrive/d/10.1/apical_top_sq/apical_top_demo_isp_youjing/pri_apical/software/fsysid/fsysid.elf] return code: 4, 'other error'
!ENTRY com.altera.sbtgui.launch 2 0 2011-06-13 12:07:00.796
!MESSAGE Obtaining system ID information for selected processor
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:00.796
!MESSAGE SOPC design not set.
!MESSAGE CPU module not set.
!MESSAGE The SOPC design does not contain a CPU of a supported architecture.
!MESSAGE CPU architecture type not set.
!MESSAGE CPU master group not set.
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:04.187
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:04.750
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.546
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.578
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.609
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.640
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.687
!ENTRY com.altera.sbtgui.launch 2 0 2011-06-13 12:07:13.703
!ENTRY com.altera.sbtgui.launch 2 0 2011-06-13 12:07:14.218
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:14.265
!ENTRY com.altera.sbtgui.launch 1 0 2011-06-13 12:07:16.343
!MESSAGE Executing: [C:\WINDOWS\system32\cmd.exe, /C, C:/altera/10.1/quartus\bin\cygwin\bin\bash.exe, -c, nios2-download '--cable=USB-Blaster on localhost [USB-0]' --device=1 --instance=0 --accept-bad-sysid --sidp=0x25018 /cygdrive/d/10.1/apical_top_sq/apical_top_demo_isp_youjing/pri_apical/software/fsysid/fsysid.elf]
!ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:22.937
!MESSAGE Failed Executing: [nios2-download, '--cable=USB-Blaster on localhost [USB-0]', --device=1, --instance=0, --accept-bad-sysid, --sidp=0x25018, /cygdrive/d/10.1/apical_top_sq/apical_top_demo_isp_youjing/pri_apical/software/fsysid/fsysid.elf] return code: 4, 'other error'
!MESSAGE Downloading ELF Process failed
I can be sure ,my sysid is right and .sopcinfo is right
1 Reply
