20 years agohelp buildroot
I am using Fedora Core 5 and I am unsuccessfully trying to follow hippo's build root guide. I have downloaded nios2linux-1.4.zip and build0411.zip into home/user/download. I have unziped the buil...
20 years ago --- Quote Start --- originally posted by jjwalk04@May 1 2006, 10:15 PM thanks for your help. you were right my problem was with me enabling the serial uart in the kernel configuration. i had enabled the serial uart, but had not enabled the consol for the uart. i had done this
[*] nios serial support
[ ] support for console on nios uart
when i was building the uclinux kernel on windows, this was how i had done it and i didn't have any trouble with my kernel booting. without your help, i probably would not have figured out was wrong. thanks again for all of you help.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14889)
--- quote end ---
--- Quote End --- No problem :-) The bug is only minor, but it would be really nice to fix it. I hadn't realized that it only occurs with kernels built on Linux, but not on Windows. Thanks, this info may help to narrow it down a little.
