20 years agohelp buildroot
I am using Fedora Core 5 and I am unsuccessfully trying to follow hippo's build root guide. I have downloaded nios2linux-1.4.zip and build0411.zip into home/user/download. I have unziped the buil...
20 years ago --- Quote Start --- originally posted by hootsmon+apr 28 2006, 09:58 am--><div class='quotetop'>quote (hootsmon @ apr 28 2006, 09:58 am)</div>
--- quote start ---
<!--quotebegin-hippo@Apr 28 2006, 11:37 AM i found the same error during libstc++ build on fc5 yesterday.
i have to disable c++ to get buildroot througt.
i forgot that you did mention this issue in previous post. thank you, again.
the buildroot svn was not updated. could you post this to them?
did you get c++ working on uclinux? --- Quote End --- Hippo, this will be my first experience at posting anything to buildroot & busybox, but no problems, I'll muddle through OK. Unfortunately I didn't get C++ working, mainly because I don't even understand how to connect up GDB debugger, in order to trace where things go wrong. I'm reasonably comfortable with GDB on the desktop, but remote debugging on the dev-board is a bit beyond me right now. The secondary excuse is I'm occupied with learning all about learning Linux device drivers (following Corbet's terrific book), so C++ doesn't seem quite so important at the moment. But it would be really cool to get C++ working, because it must be almost there I think. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14784)</div> [/b] --- Quote End --- I am really happy that more people help out. Joint the reporters on busybox.net is a great experience. They are quite active and responsive. Enjoy!
