20 years agohelp buildroot
I am using Fedora Core 5 and I am unsuccessfully trying to follow hippo's build root guide. I have downloaded nios2linux-1.4.zip and build0411.zip into home/user/download. I have unziped the buil...
20 years ago --- Quote Start --- originally posted by hippo@Apr 28 2006, 11:37 AM i found the same error during libstc++ build on fc5 yesterday.
i have to disable c++ to get buildroot througt.
i forgot that you did mention this issue in previous post. thank you, again.
the buildroot svn was not updated. could you post this to them?
did you get c++ working on uclinux? --- Quote End --- Hippo, this will be my first experience at posting anything to buildroot & busybox, but no problems, I'll muddle through OK. Unfortunately I didn't get C++ working, mainly because I don't even understand how to connect up GDB debugger, in order to trace where things go wrong. I'm reasonably comfortable with GDB on the desktop, but remote debugging on the dev-board is a bit beyond me right now. The secondary excuse is I'm occupied with learning all about learning Linux device drivers (following Corbet's terrific book), so C++ doesn't seem quite so important at the moment. But it would be really cool to get C++ working, because it must be almost there I think.
