21 years agoHelp: about the socp setting
Hi, The hardware is Cyclone EP1C6Q and EPCS4. I want to run the Nios II program from on_chip_memory. How to set the reset address, exception address and break address in the SOCP? Also, how abo...
21 years agofor a fifo interface, have a look at mike desimone's ready made solution in fifo interface (http://www.niosforum.com/forum/index.php?act=st&f=15&t=184).
Problem is though, that you wont learn so much by using this solution, so reading up on the doc's as suggested by badomen is a good idea.
