16 years agoHelp-about peripheral IP design
Hi,dear friends. Recently I have done a DAC IP as a Nios peripheral but it doesn't meet the requirment.I do this IP as the example "pwm" from Altera.com.Now I send a series number to the dac(A...
16 years ago --- Quote Start --- how about:
for(i=0;i<=24;i++)
IOWR_ALTERA_AVALON_PIO_DATA(DATAOUT_BASE,*(alt_u32* )(data_tcm_memory_ptr+i)); --- Quote End --- Yeah,I got it. I do it as you said and get the result ,but the ouput has harmonic wave and a little jitter. So I think through on-chip-memory(data saved in it) can enhance the speed ,but can not get the exact answer.When the nios do high-speed signal processing ,I'm not sure it can get the right answer . And ,I guess that the whole transmission is like this: when I put initial data in on-chip-memory,the avalon bus read the data and then write the data to output.Maybe my idea is wrong.Could you give me a suggestion how does the avalon bus work?
