16 years agoHelp-about peripheral IP design
Hi,dear friends. Recently I have done a DAC IP as a Nios peripheral but it doesn't meet the requirment.I do this IP as the example "pwm" from Altera.com.Now I send a series number to the dac(A...
16 years agoI see.Thank you for your kindness.
--- Quote Start --- some customer ips can have master and slave ports. a master like the nios cpu tells the customer ip via its slave ports that the next couple of data is stored under slave memory location 0xsomething and enables this ip functionality to fetch via its master ports the data without the help of some other master funtionality. --- Quote End --- Now if I want to design a AD IP,then it must have input ports and output ports.I'm not sure that whether the input data go into the fifo,and then fifo send the data to avalon bus,at last avalon bus write the data to AD IP register.It seems complex. Besides,I occure another problem.I made a memory initialization(use Tightly-Coupled Memory).I want to get data from the on-chip-memory to dataout ports.But it doesn't work.(in the attachment) during Nios IDE,I do like this volatile int i; volatile int *data_tcm_memory_ptr; data_tcm_memory_ptr = (alt_u32*) (0x00000000);//on-chip-memory base while(1) { for(i=0;i<=24;i++) IOWR_ALTERA_AVALON_PIO_DATA(DATAOUT_BASE,(alt_u32*)(data_tcm_memory_ptr+i)); } Best regards!
