21 years agohelp : Toshiba flash
Hi: now I found the flash using in UP3 is TC58FVB160AFT ,which offered by Toshiba , meanwhile I found a file of the " tc58xx" in the directory "\cgywin\altera\components\ecos\ecos-curr...
21 years agoHi:
Yeah ,some up3 kits come with ExcelSemi flash ,and some come with Toshiba flash . and all of the two types flash can work with default altera CFI drivers ,but now I want to make flash work on the ecos , I think the drivers of flash on ecos are different from the drivers offered by altera. so I should write the flash drivers on ecos system. meanwhile ,there are some drivers about Toshiba flash in the files of "flash_tc58xxxx.inl" and "flash_tc58xxxx_parts.inl" , but the chips included in the files are some different from UP3 flash, therefore , I want to know if I can use the default altera CFI drivers to driver the flash on ecos , if not ,how to write the ecos drivers of the flash ? thanks!
