15 years agoHELP!!- NiosII Error message and customized SRAM
Hi, I am a beginner on NiosII. I was recently attracted very much by new features provide by series of new development tools. I am currently facing two problems. I have spent more than one wee...
15 years agoprogress:
The SRAM can be built correctly when I follow below procedure: 1. add HDL file into new components 2. only keep ADDR, DATA, CS, OE, WE, BE and CLK, set them as tristate_slave(except CLK) and then delete all other ports 3. delete HDL file 4. in this case, only two ports for the new components: clock_sink and avalon_tristate_slave But if I don't use HDL, just add new signals into the new components and assign interface as tristate slave, three parts would be appeared in GUI of the components: clock_sink, avalon_tristate_slave and avalon_tristate_slave1(conduit). I don't know why one more port is appeared. I tried, but have no any clue to fix it. Does any body know? thanks
