HELP ! Can't Find C2H in Quatus 10.0SP1 Eclipse !!!!
Hello, Thank you for your rapid reply. I begin my course by designing integer SQRT function in VHDL. the second step is to use the algorithm C designed on NIOS. The 3rd step is to use C2H (in middle of January) to compare time computation. I begin with BSP concept and it is very interesting because I can modify SRAM/DRAM spaces for code and data and it permit to identify latencies depending of kind of memory and cache. It means that I cannot use C2H because I must change soft design tool and I have not more time to learn other tools and other approach different than BSP concept. Xilinx has Handle C to VHDL (powerfull tool) design tool and it's the same as C2H tool. I am the local ALtera representative of University of Paris Orsay. Is it possible to use makefile approche to add C2H for some C functions ? I read about nios2-c2h-generate-makefile command shell tool to generate C2H.MK It don't work because there is some bugs because include paths and some other thinks. this tool associated to Eclipse Tool is a good solution for me,if it work, to continue to use ECLIPSE based TOOL more perfect than the IDE TOOL ! Happy christmas
