15 years agoHELP ! Can't Find C2H in Quatus 10.0SP1 Eclipse !!!!
Hello, I need help because, I installed all softs and I have licence for C2H (university licence). The problem is that the C2H menu don't appear and cannot find it !!!!! It is not in Eclipse. is ther...
15 years agoIt was decided not to do any further development work on C2H a while ago....just maintenance. Since SBT for Eclipse (the new IDE) was developed _after_ this decision, there's no C2H available there.
The "old"/Nios II IDE method has a System Library rather than a BSP. If you want to teach/learn C2H and want a GUI to do it with, you should probably stick with the legacy Nios II IDE. As an aside, Altera's tools are definitely _not_ "messy". Perfect? No, but if you have experience with other FPGA companies and, indeed, other EDA vendors...Altera's definitely near the top with the tools they provide. Regards, Happy Holidays and you may want to post exactly what sort of courses/material you're trying to prepare or even contact your local Altera representative to see if they can guide you in a more fruitful direction... -- slacker
