15 years ago
Hello World project without return message
I built a SOPC with NIOS II/f, on-chip RAM, pll, and sysid.
NIOS II/f operates at 100MHz.
And when I trying to run hello world as NIOS II Hardware,
the following messages show in the console window:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x00081020: verified
Initializing CPU cache (if present)
OK
Downloading 00040000 ( 0%)
Downloaded 42KB in 0.7s (60.0KB/s)
Verifying 00040000 ( 0%)
Verified OK
Leaving target processor paused
the "Hello from Nios II!" is not appeared.
Is it normal?
What should I do to fix this problem?
Thanks for every trying to help me!
PS. No error or warning occurs in building & runing the hello world project
    Do you have a jtag uart and is it defined as standard output?
    How to define the jtag uart as a standard output?
    I've include a jtag uart in my system.
    Dear Daixiwen:
    I also check the jtag_uart_input_stream.dat and output_stream.dat
    There are only 00000000 in input_stream.dat and nothing in output_stream.dat
    Thanks for reply!
    --- Quote Start ---
    #define ALT_SYSTEM_NAME "unnamed"# define ALT_CPU_NAME "cpu"# define ALT_CPU_ARCHITECTURE "altera_nios2"# define ALT_DEVICE_FAMILY "STRATIXIII"# define ALT_STDIN "/dev/jtag_uart_0"# define ALT_STDIN_TYPE "altera_avalon_jtag_uart"# define ALT_STDIN_BASE 0x00081018# define ALT_STDIN_DEV jtag_uart_0# define ALT_STDIN_PRESENT# define ALT_STDOUT "/dev/jtag_uart_0"# define ALT_STDOUT_TYPE "altera_avalon_jtag_uart"# define ALT_STDOUT_BASE 0x00081018# define ALT_STDOUT_DEV jtag_uart_0# define ALT_STDOUT_PRESENT# define ALT_STDERR "/dev/jtag_uart_0"# define ALT_STDERR_TYPE "altera_avalon_jtag_uart"# define ALT_STDERR_BASE 0x00081018# define ALT_STDERR_DEV jtag_uart_0# define ALT_STDERR_PRESENT# define ALT_CPU_FREQ 100000000# define ALT_IRQ_BASE NULL# define ALT_LEGACY_INTERRUPT_API_PRESENT
    --- Quote End ---
    I've reference other project. And modify the system.h based on the corresponding parameter.
    And pass compilation, runing well.But still no "Hello XXXX" in console window.
    If you have any idea, please tell me!
    Thanks again everyone!
    Just rename the jtag_uart_0 to jtag_uart and rebuild the system.
    Set N2 terminal communication device.
    After these steps, the hello world fully works.
    Sorry for wasting your time in this stupid bug.
    It isn't time wasted, civing the solution could help others that have the same problem.
    I find it strange though, from the system.h extract that you gave, it seems that the tools identified correctly the name of your uart... Anyway I'm glad it is working now!
    --- Quote Start ---
    --- Quote End ---
    hi everyone I met this problem,can any one give me some advice?
