21 years ago
hello_world makefile
Hi people
I have made the standard hello world as a test app for my custom board.
Makefile
include Rules.mak
ECLIPSE_WORKSPACE := /cygdrive/c/altera/kits/nios2/bin/eclipse/workspace
KERNEL_PROJECT := hello_world
BUILDDIR := $(ECLIPSE_WORKSPACE)/$(KERNEL_PROJECT)/build/include
CFLAGS += -O0 -g -I$(BUILDDIR)
all: hello.exe hello.gdb
Rules.mak is the standard file and has not been modified.
When I try to compile the code shown here below the error below the code is shown.
Code: hello.cpp
#include "stdio.h"
int main(int argc, char *argv)
  printf("Hello world test app!!!\n");
  return 1;
console : compiler/linker
make -k all
  no emulation specific options.
nios2-elf-gcc -nostdinc -D__linux__ -O2 -I"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -O0 -g -I/cygdrive/c/altera/kits/nios2/bin/eclipse/workspace/hello_world/build/include -Wall -o hello.o hello.cpp
nios2-elf-gcc -r -d -L"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib -o hello.bin hello.o /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a "c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/libc.a
hello.o(.text+0x0): In function `_start':
: multiple definition of `_start'
/cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/crt0.o(.text+0x0): first defined here
collect2: ld returned 1 exit status
make: ***  Error 1
make: Target `all' not remade because of errors.
Hope some of you can tell me what I am missing here.
thx upfront.
Michael E
    Hi
    Just an update
    1) have changed my makefile to the one shown below
    # #  configurable options#   - set DEBUG = 1 to turn on debugging support#
    DEBUG = 1
    PROJ_NAME = hello
    INSTALL_DIR =
    PROGS := $(PROJ_NAME).exe
    CFLAGS +=
    # #  You should not need to modify anything beyond this point# # TOPDIR = ..
    include Rules.mak
    ifeq '$(DEBUG)' '1'
        PROGS += $(PROGS:.exe=.gdb)
    endif
    all: $(PROGS)
    .PHONY: clean
    clean:
        -rm -f *. *.elf *.gdb *.bin *.exe
    .PHONY: install
    install: all
    ifeq "$(INSTALL_DIR)" ""
        $(error No installation directory specified)
    endif
        mkdir -p $(INSTALL_DIR)/bin
        install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
    2) I have compiled a custom uClibc library ( used the guide for this )
    3) Have tried overwriting the lib folder with the new files created by my custom compilation.
    c:\altera\kits\nios2\bin\eclipse\plugins\com.microtronix.nios2linux.uClibc_1.4.0\lib
    has been replaced by the files from
    C:\altera\kits\nios2\examples\software\linux\ECTKernel\lib
    Still I get the console output
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    make -k all
    nios2-elf-gcc -nostdinc -D__linux__ -O0 -g -I"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -Wall -o hello.o hello.cpp
    nios2-elf-gcc -msys-crt0="c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/crt0.o -r -d -L"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib -o hello.bin hello.o /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a "c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/libc.a
    hello.o(.text+0x0): In function `_start&#39;:
    : multiple definition of `_start&#39;
    c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/lib/crt0.o(.text+0x0): first defined here
    make: *** [hello.bin] Error 1
    make: Target `all&#39; not remade because of errors.
    rm hello.o[/b]
    --- Quote End ---
    sugestions???
    Michael E
    Why not hello.c instead of hello.cpp?
    I test when *.c change to *.cpp, the same error occurs. So in my opinion, if you insist to *.cpp you should add some proper FLAG to tell compiler to compile *.cpp.
