16 years agoHello world driver example on the wiki
I tried the hello world driver example on the wiki.
>>http://www.nioswiki.com/operatingsystems/uclinux/moduleprogramming The static driver(compile-in) works. I saw the hello, world in the kernel boot time. However, I can not get the loadable module version worked. I do have the hello.ko file in the lib directory. /lib/modules/2.6.30-00494-g84a224b-dirty/kernel/drivers/misc/hello.ko I followed the setting, so the make file and kconfig and other stuffs should be all right. But I can not find the make user/busybox_clean Under the ~/uClinux-dist dir BTW, I am using the MMU version. Is that why I can not find this busybox_clean command??? I feel like the hello.ko file itself is fine...so that is why the build-in version works. After the kernel loaded, whenever I did the insmod or modprobe, kernel just stack. No response at all. I tried with insmod hello.ko & Then, it seems like adding this driver, but can not see the "hello, world" and just hangup at there. Full path for the hello.ko did not work. I tried other super simple module drivers, but did not work. BTW, I could not jump the other reference link http://www.icwin.net/showartitle.asp?art_id=8452&cat_id=52 It's no longer exist.No RepliesBe the first to reply
