19 years agoHello world build error!
Hi all, When build the hello_world.c, I encount a error, Is any one can help me out? the hello_world.c as follows: #include <linux/init.h># include <linux/module.h># include <linux/kerne...
19 years agodidn't you try
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C ~/uClinux-dist/linux-2.6.x M=`pwd` modules which you will need to compile device drivers instead of nios2-linux-uclibc-gcc linux-2.6.x/drivers/misc/hello.c -o hello -elf2flt="-s 4000" which suits for user programm. You will find detailed explanation in the kernel docs. hope this helps, but i'm not a kernel crack maybe you take a look at the nioswiki for the module programming example. by the way let me ask you, what do you want to do? do you want to write a device driver or a user program.
