21 years agoHello_led can not run on Nios II/s core.
Hi, I use the Microtronix Cyclone Dev.Board, and follow the Altera Hardware Design and Software Design. When I make the LowCost HardWare Design(use the Nios II/e Core and epcs_controller ...
21 years agoHello benmidgley,
<div class='quotetop'>QUOTE </div> --- Quote Start --- Do you have any insight into what the problem was with the core you were using.[/b] --- Quote End --- My SDRAM is MT48LC2M32B2. I just found that there is the single Micro MT48LC2M32B2-7 chip in the Presets: menu of sdram_controller(new_sdram_controller). I choose this. Do not change anything. Then, my system can run.
