21 years agoHello_led can not run on Nios II/s core.
Hi, I use the Microtronix Cyclone Dev.Board, and follow the Altera Hardware Design and Software Design. When I make the LowCost HardWare Design(use the Nios II/e Core and epcs_controller ...
21 years agoHello,
I have solved the problem by changing the SDRAM Controller Core. I think it is the bug of SDRAM Controller Core(the new_sdram_controller provided by nios2 kit ). I use the SDRAM Controller Core of SOPC Builder 2.7 Provided instead. The program can run and led is lightened. Why? But the new_sdram_controller_core can used by Nios II/e Core and all test programs can run with Nios II/e Core normally. When use Nios II/s Core, I must use the old sdram_controller_core instead. My Dev board is Microtronix Cyclone Development Board. I have read the .ptf file of each controller core, but I do not know exactly which part can disable my system. Can tell me the reason? Thank you.
