21 years agoHello_led can not run on Nios II/s core.
Hi, I use the Microtronix Cyclone Dev.Board, and follow the Altera Hardware Design and Software Design. When I make the LowCost HardWare Design(use the Nios II/e Core and epcs_controller ...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- It has nothing to do with USBblaster cable (just bypass the warning), but you'd better buy a UART cable. It is cheap and important for run/debug nios II applications. In fact, UART cable is necessary to you, I think.[/b] --- Quote End --- What problems are you having which force you to use a standard UART? I've been using a JTAG UART for ages with no problems.
