21 years agoHello_led can not run on Nios II/s core.
Hi, I use the Microtronix Cyclone Dev.Board, and follow the Altera Hardware Design and Software Design. When I make the LowCost HardWare Design(use the Nios II/e Core and epcs_controller ...
21 years agoIt has nothing to do with USBblaster cable (just bypass the warning), but you'd better buy a UART cable. It is cheap and important for run/debug nios II applications. In fact, UART cable is necessary to you, I think.
