21 years agoHello_led can not run on Nios II/s core.
Hi, I use the Microtronix Cyclone Dev.Board, and follow the Altera Hardware Design and Software Design. When I make the LowCost HardWare Design(use the Nios II/e Core and epcs_controller ...
21 years agoYes, I have tried to use f/Core, the same result(bad on s/Core) happen.
----------------------- First, I generated the system(I made the system with the standard HW design component, but I did not have lcd, so I deleted the lcd) with e/Core and everything is OK.(hello_led,memtest, board_diag and so on). I use Microtronix Cyclone Board(I borrow from other, the board was made in 2003. So Sometimes I think if it is the wrong of the board, but no infor from Microtronix said the revision of the board). My system include sram/flash/sdram/epcs_controller/igor_mac/uart/led_pio/button_pio/sevenseg_pio/system_timer/jtag_uart. ----------------------- Second, I regenerated the system only changed by s/Core. I tried the hello_led in Nios II IDE, it can not run. I found in debug, the program stopped in the line 117. I set breakpoint and click Resume, but nothing run and program still stay at line 117. I have no USB, no UART cable......, I only have on ByteBlaster cable connectted. I also have no LCD. ----------------------- Then, I changed back to Nios II/e Core, the program can run again. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Here is my console information when I run the s/Core. ------------------------------------------ Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: OK Reading System ID at address 0x021208B8: verified Downloading 00000000 ( 0%) Downloading 01000020 ( 4%) Downloaded 1KB in 0.0s Leaving target processor paused ------------------------------------------- nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios nios2-terminal: II systems. You may experience intermittent JTAG communication nios2-terminal: failures with this cable. Please use a USB Blaster revision B nios2-terminal: cable or another supported cable. Please refer to the file nios2-terminal: errata.txt included in the Nios II development kit documents nios2-terminal: directory for more information. nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0 nios2-terminal: starting in terminal mode (Control-C exits) ---------------------------------------------- Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x021208B8: verified Listening on port 1058 for connection from GDB: accepted ---------------------------------------------- When I click Resume Button, nothing appears in console. When I click step into Button, nothing happens and then I click suspend Button, it display Nios II ELF Debugger error. "Target request failed: Failed to interrupt." and the program can not be suspended. I do not try Q4.2 SP1. I have no idea yet.
