21 years agoHello_led can not run on Nios II/s core.
Hi, I use the Microtronix Cyclone Dev.Board, and follow the Altera Hardware Design and Software Design. When I make the LowCost HardWare Design(use the Nios II/e Core and epcs_controller ...
21 years agoHave you seen similar (bad) results if there is an 'f' core in the system? Also are you regenerating the hardware or using the sof file supplied with the kit?
One more thing, what do you have the USB cable connected to? I found having that board connected to my LCD monitor was problematic (noise from the monitor messed up communication with the board). I really doubt this is the cause for you though. Can you copy and paste what appears in the console window. Also have you tried Quartus 4.2 SP1?
