21 years agoHello_led can not run on Nios II/s core.
Hi, I use the Microtronix Cyclone Dev.Board, and follow the Altera Hardware Design and Software Design. When I make the LowCost HardWare Design(use the Nios II/e Core and epcs_controller ...
21 years agoBut It do not happen with Nios II/e Core.
My HW/SW environment is --------------------------------- Quartus II 4.2 Nios II 1.1 Eval Microtronix Cyclone Board --------------------------------- I have tried other example, like Hello_world. When run debug as..., the program stop at main() and can not run any more. I installed the Quartus II 4.1(SP2) and Nios II 1.0, the same problem happened. I will try again to find some clue and paste. Thank you.
