21 years agoHello_led can not run on Nios II/s core.
Hi, I use the Microtronix Cyclone Dev.Board, and follow the Altera Hardware Design and Software Design. When I make the LowCost HardWare Design(use the Nios II/e Core and epcs_controller ...
21 years agoI think you need to provide more information.
What does the debugger output display in this case? Can you debug the design (clicking on the beetle rather than the running man)? If not then which error messages come out of nios2-download and nios2-gdb-server when you try to debug it?
