LVo001
7 years agoHello, Are there updated HAL drivers that support a 32 Gig FAT32 SD card?
I've been working with the following SOPC example ftp://ftp.intel.com/pub/fpgaup/pub/Intel_Material/15.1/University_Program_IP_Cores/Memory/SD_Card_Interface_for_SoPC_Builder.pdf I've built and co...
EBERLAZARE_I_Intel
7 years agoHi,
Have you tried using the 2GB SD card to see if it work correctly?
Based on the design example, the current version of the driver supports only FAT16.
Also, based on my knowledge, the FAT32 driver is commonly used in cards for 4GB and 32GB, so I am unsure if you are able to use the 32GB SD card for this example.
Regards.
