13 years agohaving trouble with interrupt
Hello everyone ,
I'm try for a very long time to do a simple interrupt with nios ii. this is my problem: i have button in sratix ii dev kit and all i want to do in nios is just to turn on led (with interrupt) when the button is pressed. i defined rising_edge and all the others in sopc and i checked that the button is connected to the sopc module in quartus. everything passed the compile but when i run the debug the program ignore my clicks on the button and do nothing. this is my program: the program ignore my clicks and doesn't get to here :\ void led_interrupt() { //turn on led// //Delay// } void main() { alt_irq_registerr(button_IRQ, led_interrupt ); //turn off led// while(1); // waiting for interrupt; } I hope somebody can help me. sorry for my bad english:) thanks you(:3 Replies
Add these before alt_irq_register:
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(button_IRQ, <irq_bit_mask>); // enable irq IOWR_ALTERA_AVALON_PIO_EDGE_CAP(button_IRQ, <irq_bit_mask>); // clear irq You also need to clear the edge capture bit in irq handler function, otherwise the irq will keep on retriggering. Also make sure of these points: - in qsys/sopc button pio must be defined with interrupt capability enabled - the button pio is correctly routed to fpga pin and pio is working: begin with polling the pio in while loop to test this point. - Altera_Forum
Could you elaborate on the definition of "irq_bit_mask"? In SOPC builder, my PIO IRQ (width = 1 bit) is on IRQ line 9. Does this mean my "irq_bit_mask" is bit 9? - Altera_Forum
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(button_base_address,1); // enable irq
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(button_base_address, 1); // clear irq Infact you are using PIO bit 0, then mask = 1. For clarity: if you had a 8 bit wide PIO and you connected the button to pio_input[6], then you'd had irq_bit_mask=0x40 IRQ line nr is involved only in alt_irq_register() call.
